Mentor Graphics
Mentor Embedded Inflexion UI: Delivering stunning 3D User Interfaces
Mentor Embedded™ Inflexion™ UI enables users to implement compelling and visually rich user interfaces (UIs) with significantly reduced effort; allowing users to meet the UI demands of today’s embedded devices. From highly animated and visually rich 3D UIs for Android™- or Linux-based consumer devices, to Linux- or RTOS-based industrial controllers, Inflexion UI solves many of today’s more demanding UI implementation problems.
Inflexion UI is an OpenGL® ES-based solution which allows Mali users to create and deploy stunning 3D GUI designs in a drag and drop environment, without any graphics know-how or low-level programming skills.
3D is here, and now Mentor Embedded are making it easy! Inflexion UI will soon offer features to create stereoscopic 3D UIs for new consumer products including 3D TV products such as digital TV, IPTV and set top box, and touch screen products such as smartphones and tablets with autostereoscopic (“no glasses”) displays.
Drag and drop UI construction
Makes it fast and easy to create animated designs, shortens development cycles, no specialist skills.
3D & Animation
Create Animated and/or 3D UIs without having to understand OpenGL ES. No need for expensive skilled resources & shortens development cycles.
Preview & interact with UI design on PC
Improved workflow avoiding design, code, test cycle. Shortens development time and fosters better team interaction.
Separation of UI from application code
UI can be developed independently from application code, allowing for parallel development and an easy change of UI for specific markets, customers or products.
Eclipse Plugin for Android
Integrated with Google’s Android tool chain to enable easy and rapid development of Inflexion-based Android applications.
To find out how to buy Inflexion UI email: inflexion@mentor.com
Inflexion UI exploits Mali’s Full Screen Anti-Aliasing (FSAA) and highly optimized rendering pipeline to deliver the rich detail and smooth animation effects demanded by the next generation of embedded 3D user interfaces.
Press Release
Mentor Graphics Optimizes the Mentor Embedded Inflexion UI for Use on ARM Mali GPUs
3D is here, and now Mentor Embedded are making it easy! Mentor Embedded Inflexion UI will soon offer features to create stereoscopic 3D UIs for new consumer products including 3D TV products such as digital TV, IPTV and set top box, and touch screen products such as smartphones and tablets with auto stereoscopic (“no glasses”) displays.
Try Now! Download a stereoscopic 3D demo for the Samsung® Galaxy™ SII smartphone, created with Inflexion UI and harnessing the power of the handset’s ARM Mali-400 MP graphics core. Requires red/cyan anaglyphic 3D glasses (also distributed at select events).
If you do not have a Samsung Galaxy SII smartphone, view the 3D video of the demo. Requires red/cyan anaglyphic 3D glasses (also distributed at select events).
Visit Mentor Embedded website for more information
